93 Civic Fuel injector issue? - HondaCivicForum.com
Reply
Old 07-25-2013, 10:10 AM
Default 93 Civic Fuel injector issue?
I have a '93 Civic DX D15B7
It has been a very reliable car but last Tuesday it failed to start after sitting for 3 days. Here is what I have done so far:
Car turns over, all valves are moving
I have spark but no fuel at the cylinders
I have fuel at the fuel rail.
I swapped the ECU (junkyard, not a known good one) with no luck
The car acts the exact same with either ECU or no ECU at all installed.
No CEL or code to go off of
Tried disconnecting the TW switch and it finally gave a CEL.
Basically the Fuel injectors are not operating, it had no symptoms leading up to this to this.
Any ideas would be appreciated, Thanks
Mark
Old 07-25-2013, 10:46 AM
droopy128's Avatar
Try swapping out the main relay..
Old 07-25-2013, 11:29 AM
Well never mind, wouldn't you know it I monkey with it for 2 days to no avail only to figure it out 1 hour after posting here. Turns out it was the TW switch, but I needed a jump start because the battery was low by the time I tried disconnecting the switch.
Old 04-18-2017, 04:54 PM
Quote:
did you replace the TW switch or was it just not connected?
Reply
Thread Thread Starter Forum Replies Last Post
2009 Honda Civic, start issue, idle issue, AC issue? mudhenFUF Mechanical Problems & Technical Chat 5 08-21-2013 06:36 AM
91 Civic DX fuel injector help! brian91civic Mechanical Problems & Technical Chat 6 09-09-2009 05:43 PM
95 Civic dx 1.5l Engine/ Dist./maybe injector issue BIGBOYNET Mechanical Problems & Technical Chat 4 02-02-2009 09:06 AM
NEED FUEL INJECTOR PLUGS FOR A 96-00 HONDA CIVIC 92CIVICHB Private 'Wanted' Classifieds 0 07-15-2006 03:51 AM
Fuel Injector Problem tominrm Engine & Internal 2 04-10-2005 08:23 AM
Tags
b16a2, fuel, honda, injector, issues
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
