95 Civic LX TPS, MAP, or?
Actually a new IACV is about $150 - $200, but usually it is just dirty.
Also check that the cooling system is full. Engine cold, take off the radiator cap, it should be full to the top. Bubbles in the engine will cause the idle to surge.
I am having a similar problem with a '95 Civic sedan 1.5L engine. New car (to us) for my daughter. It has 100K on it, literally driven by a grandma since the dealer. Previous owner (grandpa) replaced the radiator to address a coolant loss issue. When we bought it we checked the oil and as I feared there was coolant in the oil. The owner sold it for $500 and we had the head gasket replaced. The erratic idle was present before the sale. We checked the cooling levels, and replaced the AIC (easy first step). Still idleing fast and slow until you drive it 20 minutes. The nest step appears to be the fast idle valve below the throttle air intake. We took it to a garage and they confirmed, saying that the wax pellet that is part of he valve is degraded and the culprit. I cannot find the correct replacement part (16500-P28-A50). Does anyone on thsi forum have a line on where to get this part (new)?
Fast Idle Valve
DefaultI am having a similar problem with a '95 Civic sedan 1.5L engine. New car (to us) for my daughter. It has 100K on it, literally driven by a grandma since the dealer. Previous owner (grandpa) replaced the radiator to address a coolant loss issue. When we bought it we checked the oil and as I feared there was coolant in the oil. The owner sold it for $500 and we had the head gasket replaced. The erratic idle was present before the sale. We checked the cooling levels, and replaced the AIC (easy first step). Still idleing fast and slow until you drive it 20 minutes. The nest step appears to be the fast idle valve below the throttle air intake. We took it to a garage and they confirmed, saying that the wax pellet that is part of he valve is degraded and the culprit. The garage gave us the part # (16500-P28-A50). My research shows that this is not the correct part for a 1.5L sedan, and that we should use 16500-P06-A00 (this appears to be a better fit/closer to the existing part)
Can anyone on this forum confirm which part is correct? And as both parts appear to be discontinued, do you have an online place to get this part (new)?
Wilsonscivic
08-12-2011 02:59 PM
arguablybetter
12-07-2009 01:26 PM
shelleymae
04-14-2009 11:23 PM
Pyr0TeK
03-29-2007 02:34 PM
