95 Honda Civic Driver Side Inner Tie Rod
Old 09-20-2008, 02:16 PM
lee norman's Avatar
Default 95 Honda Civic Driver Side Inner Tie Rod
How does one install the driver side inner tie rod for a 95 Honda Civic EX.
When I was replacing the outer tie rod and Bellows I noticed the inner tie rod was loose. The inner tie rod would drop by itself after I removed the outer tie rod. Should the inner tie rod be that loose?
It was difficult to replace the belows since I was not easy to reach. It appears to be difficult to reach the inner tie rod. Not sure if I can get a wrench to loosen the inner tie rod. Does it take a special tool to remove the inner tie rod? Haynes manual did not give any information for removing the inner tie rod.
If someone has removed an inner tie rod on the passenger side and has understands what needs to happen to remove and install an new inner tie rod, I would appreciate the help. Thanks
Old 09-20-2008, 05:54 PM
bwit43's Avatar
Loose as in it just dangles there no real stiffness? Is there any play if you pull it in and out? not turnin the whole rack but just the rod pops in and out?
Old 09-20-2008, 07:27 PM
lee norman's Avatar
Default Loose
Loose meaning no resistance when turning the inner tie rod. It does not pull in and out but turns and moves up and down with no resistance
Old 09-20-2008, 08:24 PM
Is power steering fluid leaking from the boot covering the loose inner tie rod?
Old 09-21-2008, 04:19 AM
lee norman's Avatar
The boot was broken and lost its seal on the smaller side. It appeared there was something leaking, either grease and/or power steering fuid.
Old 09-21-2008, 05:31 AM
The fluid is most likely power steering fluid. Is the level low in the reservoir?
You may need to replace the entire power steering rack to fix your problem.
Old 09-21-2008, 06:22 AM
lee norman's Avatar
Just checked the power steering level. It is ok. It has not been filled in a long time. If it is leaking power steering fluid, it is very slow.
Does it sound like the inner tie rod on the driver side needs to be replaced? If so, can you replace it without replacing the entire steering rack. If so, how?
tracystravels
10-07-2020 06:52 AM
darren509
09-18-2011 07:45 AM
lee norman
05-02-2009 11:03 AM
CoolAsAFan23
12-12-2007 09:48 AM
foozball
01-17-2005 12:26 PM
Quick Reply: 95 Honda Civic Driver Side Inner Tie Rod
