96 Civic CX Overheating Even After ...
Our 96 Civic begin overheating.
I took several steps in diagnosing and attempting to repair the problem:
1. The radiator fan does run when you jump the thermoswitch connector.
2. Replaced the thermostat.
3. Replaced the radiator cap.
4. Tested radiator relay switch and it is working.
5. Replaced thermoswitch.
4. Replaced the radiator.
5. Lifted front end and bled air from the radiator.
Still overheating.
As additional diagnostic information:
No milkiness in the oil or transmission fluid, no water or vapor emitting from the tail pipe.
Some folks say the next step is the water pump? Does that sound right?
I've replaced belts on vehicles, pulled and replaced alternators, etc. Is the water pump on the 96 Honda Civic something a shade tree mechanic like me can handle?
Still overheating.
Overheating
Block test the engine. Parts store will rent you the tool and you can buy the fluid. Make sure you don't have head gasket problem. Does your cooling fan run at all? Run the engine without a thermostat to see if the fan works when the coolant reaches the right temp.
As far as if you can do it, absolutely, you can do anything man! It is a very important thing to do and I would use extreme caution in handling that type of project but as long as you don't move the cam sprocket when it is at top dead center than you should be able to do it depending on how handy you are with a wrench. 9 times out of ten you need a harmonic balancer puller kit to take off the harmonic balancer. You need to remove these driver side tire to access the harmonic balancer. Usually you will want to buy a timing belt kit which often times you can find one that comes with a lot; timing belt, water pump, idler pully, gaskets and a new idler pully pin. A savvy mechanic can do the job in less than 5 hours someone that is tackling it for the first time without all the air tools and lift, probably take anywhere from 8 to 18 hours lol maybe longer if you get stuck on something. There are multiple videos on YouTube to DIY.
Today we pulled the water pump.
Blades show NO sign of corrosion, and the blades turn with the pulley, which spins freely.
When we removed the water pump, a good bit of coolant ran out -- I am not sure if that additional fact is diagnostic of anything.
So, at this point, we've determined that
And we have replaced
the thermostat.
the radiator cap.
the thermoswitch.
the radiator.
We also tested radiator relay switch and it is working
and we
We lifted front end and bled air from the radiator.
Having checked the water pump and found it in excellent condition, am I left with a cracked block?
If it doesn't overheat when the exterior temperature is below 40 degrees, is that diagnostic of anything.
This bad boy is going to the used parts lot if I can't get a line on something else soon.
Your help appreciated.
So it's not the water pump ....
So we have gotten back to the Honda Civic 1996.
the thermostat.
the radiator cap.
the thermoswitch.
the radiator.
and we
the thermostat.
the radiator cap.
the thermoswitch.
the radiator.
and we
excivic2001
07-15-2011 10:29 PM
anivast999
05-14-2011 06:15 PM
jmack
03-15-2011 04:27 PM
sik92civic
02-27-2011 01:09 PM
fk
08-21-2008 08:46 AM
