96 Civic Ex - Oil leak
Hello all ,
I have a very very slight oil leak that has dumbfounded me. I mean literally a drop of oil now and then. I will try to explain this best I can.
The drop of oil is on the passenger side of the car or the right side of the cat converter. On a piece of metal that is impossible to see behind. It was fresh oil and does not always build up enough to fall to the ground. Not near the oil pan, not right under the oil filter or PCV. All of which I checked anyway.
I also checked the VTEC Solenoid, the valve cover gasket.
Any help is much appreciated.
Thanks,
MP.
Thanks,
MP.
Very much appreciated.
I can't seem to find the rear seal only the front seal. Is it called by another name?
If it's loacted right near the VTEC Solenoid wouldn't I see where the oil is coming from. I have to look in that area closer when I get home.
Assuming you mean this...
theRDRman
11-28-2011 04:18 PM
oilltd
06-10-2008 04:06 PM
oilltd
South West
06-10-2008 03:07 PM
