96 Civic Oil leak....
Old 01-17-2015, 11:42 AM
Kyle700's Avatar
Default 96 Civic Oil leak....
I have a oil leak from the timing belt side, doesn't look like the cam seal the top cover is blocking my view, but I don't see anything running down behind it), crank seal is dry. I have all the belts off but need to start it to get the oil flowing to find the leak, any problems with that? PS, A/C and alternator belts are off the pulley...valve cover gasket is new, no problems there.
What else can leak on the drivers side of the engine?
Old 01-17-2015, 12:46 PM
Kyle700's Avatar
Didn't have to start it, looks like it is the oil pan gasket, leaking right below the crankshaft...
Old 01-18-2015, 04:32 AM
It is OK to test run the engine with the timing cover and external belts removed, but you must put the crank pulley back on and tighten the bolt so the timing belt doesn't come off.
The oil pump is attached to the block right behind the timing belt and crank seal and there are plenty of places for it to leak oil, though such leaks are not common.
Old 01-19-2015, 08:22 AM
Kyle700's Avatar
Thanks mk378, that's the answer I was looking for. I am going to replace the oil pump seal while I am there just to cover all my bases.
theRDRman
11-28-2011 04:18 PM
shadow_93
12-28-2009 11:26 AM
oilltd
06-10-2008 04:06 PM
mokijo2
12-27-2007 12:11 AM
Quick Reply: 96 Civic Oil leak....
