94 civic dx hard starting
Old 03-23-2012, 08:37 AM
txpro's Avatar
Default 94 civic dx hard starting
Ok, so this is my situation:
Engine is D15B7
Car will start perfectly when cold and in very cold conditions. Now, after driving for 10-15 min until the engine is at operating temperature, I'll turn it off. I am able to start it back up immediately no problem. But, if I let it sit for 20+ min or so, it will be hard to start. I have to crank it for at least 5-10sec then it will start at very low rpms then reach normal idle eventually after 10sec or so. It will start normally after sitting for ~3-4 hrs. No CEL.
Known issues:
These were happening prior to the hard start issue.
-Random misfires only when cold. After engine warmed up no more misfires. (been like this for awhile)
-Guessing very minor head gasket leak (very little amount of white smoke from exhaust)
Things I have done so far:
-Main relay is good, fuel pump comes on etc
-Flushed coolant (Honda brand) + new hoses + thermostat
-Replaced ETC sensor
-Replaced spark plugs, wires, distributor cap + rotor
Possible causes:
-leaking fuel injector (but the exhaust isn't black when it starts up after the hard start)
-coolant in cylinder (when I get it to start I don't see much or very little white smoke)
I'm not sure what to do. I thought I'd post this before I take it in. I appreciate any advise. Thanks
Old 03-23-2012, 01:18 PM
droopy128's Avatar
Possible weak spark (dizzy problem) and/or leaky injector as you mentioned.. someone will chime in..
Old 05-25-2012, 12:55 PM
txpro's Avatar
for the record, my culprit was the head gasket.
whittier97370
08-29-2010 04:41 PM
cfauvel
35
11-01-2008 01:48 PM
skeeterss98
05-24-2008 08:59 AM
Pete
11-09-2006 04:48 PM
troutman
03-25-2006 03:20 PM
Quick Reply: 94 civic dx hard starting
