97 Civic starts but wont come out of park unless I use the key slot to unlock it
I have a 97 honda civic that wont come out of park unless I use the override slot to unlock the shifter. I have replaced the brake switch, the master cylinder and it has ample fluid, the solenoid switch, and the neutral safety switch. I do notice when I first turn on the ignition, just for a brief second, the solenoid opens and closes, but after the car is started the solenoid wont unlock when I depress the brake. Could the ignition switch be bad, or shorted? Do you have any other solutions?
Yes the brake lights work, and the fuses are good. I do notice that the top center light flashes on and off when the brakes are held down, but the other two brake lights are on steady. ???
I guess everyone out there is as clueless as I am when it comes to my shifter unlock problem! I know it has to be a minor thing causing this and I can't afford to take it to the dealer, so I have two options.....break the plastic locking mechanism and not have the safety feature, or take it to the salvage yard and get $500.00 for the car and start over. Thanks guys!
Well guys it wasn't the brake wiring causing the problem. I was getting a TPS code along with the shifting problem, so when I replaced the TPS, the shift problem went away and is working correctly now. I guess the TPS voltage had something to do with the unlock switch not working right. Thanks for the replies. I hope this inf helps others.
Mecca8383
03-31-2014 05:15 AM
canderific
01-05-2013 12:15 PM
jerrys
07-07-2011 08:37 PM
tlkolrod
01-24-2009 03:45 AM
tlkolrod
12-22-2008 09:07 AM
