98 civic 1.6L / no idle - help
Daughter ran it hot, head gasket blown. Torn it down, had head checked out, valve job done, had to shave the head some ( warped ). Re-installed, replaced timing belt, water pump. Set back in time. Engine cranks and runs fine ( upper rpm ), has issue idling, some times it idles fine, then doesn't. Went to check ignition timing but is moving around to much. I had a 94 civic 1.5L and it had a green plug under the dash passenger side that I would short, this would bypass the computer and I could set ignition timing and then remove my jumper.
Question is: Does a 98 civic have then plug? If so where is it located ?
It runs in the upper rpms so well I am sure the timing belt is correct. I had the cam sprocket lined up on the two marker and in the up position, lined the crank with the key at the 12 O'Clock position and with the notch to the oil pump. Rotated engine counter clockwise a 1/4 turn and then some to adjust tensioner. Re-checked and with the balancer on and the tdc mark lines up where it is suppose to.
No check engine lights......
Any ideas or suggestions would be appreciated. I do not have a manual for the 98, did look around town and Advance, Auto zone do not have it is stock. Would like to get this solved before Monday. If not then I will order a manual.
Thanks for any help,
John
John
RE: 98 civic 1.6L / no idle / help
ORIGINAL: jwenzell
John
John
Okay, found the manual on this site and downloaded it. Stayed up late and studied it. Went out this morning, ran a couple test. When I cranked it this morning (cold ) it idled fine until it reached temperature this same thing poor or no idling. When I unplug the knock sensor it idles fine.
I did find the plug under the dash and tried to jump it and set timing, no luck. I did hear some valve train noise. Could the knock sensor pick this up?
Will adjust valves and re-check timing tomorrow night.
Does any one have any ideas........
Please help.
John
ORIGINAL: jwenzell
Please help.
John
ORIGINAL: jwenzell
John
John
Please help.
John
Removed valve cover, rechecked timing belt, all was good.
Checked the valve adjustment and that was the issue. Valves were to tight, I asked the machine shop when I picked up the resurfaced hard (valve job) if he adjusted the valves he said yes. Just goes to show you.
Now itpurs like a kitten...
Thanks for the manual download.
Also thanks for all the input guys..........[:@]
John
honvic
09-02-2011 09:49 PM
JBaris
11-22-2010 03:56 PM
1badmanx
11-30-2005 12:10 PM
jlh911
06-27-2005 08:23 PM
