98 civic ac blows cold then warm
Old 09-24-2012, 05:48 AM
Slammed98silvercoupe's Avatar
Default 98 civic ac blows cold then warm
Hello, a few days ago my 98 civic started to blow cold then warm ac, cold then warm again around 3 pm when it was around 95 outside. At night time it was cold all the time. I also noticed that the compressor was not cycling off at all. The next day the ac was cold and hot, cold and hot, then at night I heard a noise coming from my engine and smoke coming from the engine compartment. My ac compressor was sparking and not spinning. I turned off the ac but not sure where the system stands at this time. What is going on? If anyone can give me any suggestions I would appreciate it. I have not checked the pressures as I do not have a set of good ac guages. Was the original problem low freon, or oil. Right now there is no gap between the coil and compressor.
Old 09-24-2012, 06:46 AM
oh and by the way the clutch will not spin all the way around, it gets stuck at a certain point.
Old 09-24-2012, 10:30 AM
Sounds like the compressor is bad. With engine off, the inner shaft (on the clutch plate) should turn freely with just a little "once around" bump. Or the pulley bearing is wobbling so bad that the clutch doesn't work right.
TexusMain
06-14-2012 04:40 PM
Firecivic
04-14-2010 05:00 PM
randy95
12
09-23-2009 01:56 AM
staffordgt
05-08-2009 11:22 AM
general23cmp
12-20-2008 10:43 PM
Quick Reply: 98 civic ac blows cold then warm
