99 Civic Fuel Level Gauge Stuck on Full
Old 10-27-2013, 07:06 AM
Originally Posted by alpinegroove
I guess I am still confused. How could there be continuity between the Yel/Blk and the body ground if both connectors are unplugged? In other words, what could be causing such a short? Since the connectors are unplugged, it couldn't be sending unit or the cluster. So what could it be?
Step back.
Step 1 - Do the sending unit unplug test.
Step 2 - Post the result.
The result may or may not indicate a short.
You need to know the test result before discussing a short and where it may be located --> there may not be a short as the unplug test was not done correctly. However, detecting a short in a wire would generally mean the bare wire is contacting a metal ground (break in wire insulation).
  #22
Old 10-27-2013, 07:24 AM
alpinegroove's Avatar
Yes, I understand I need to repeat Step 1, and unplug the correct connector. I was just trying to understand how this works.
Thank you.
  #23
Old 10-28-2013, 04:14 PM
I unplugged this connector, turned the ignition switch to ON II, but the fuel gauge is still on full.
Attached Thumbnails 99 Civic Fuel Level Gauge Stuck on Full-img_0026.jpg   99 Civic Fuel Level Gauge Stuck on Full-img_0025.jpg
  #24
Old 10-28-2013, 04:22 PM
Now do the short test on the Yel/Blk wire.
  #25
Old 10-28-2013, 04:30 PM
Unplug the harness from the cluster and then do a continuity test from the Yel/Blk pin to any metal around it, like the metal that the seat rests on? Sorry, this will be my first continuity test on a car...
  #26
Old 10-28-2013, 04:33 PM
Yes, continuity to body ground test. You can use the black ground wire in the 3P connector as ground.
  #27
Old 10-28-2013, 05:48 PM
That makes a lot more sense.
Does it matter if I do this on the cluster end of the wire or on the sending unit's side?
  #28
Old 10-28-2013, 05:52 PM
No. Either or both should be fine.
  #29
Old 10-28-2013, 05:54 PM
Will certainly be cleaner and less sticky on the cluster side...
  #30
Old 10-28-2013, 07:59 PM
If you pull the cluster, first check if the wire is shorted to ground, should be open circuit. Then plug the tank back in and measure resistance from the wire at the cluster plug to ground again, testing all the way through the circuit. Depending on how much gas is in the tank, it should be somewhere between about zero ohms (tank full) and 40 ohms (tank empty). If that checks out, the cluster must be bad.
Quick Reply: 99 Civic Fuel Level Gauge Stuck on Full
