99LX dies after battery & oil light come on
Old 08-12-2014, 05:28 PM
mxpx4182's Avatar
Default 99LX dies after battery & oil light come on
Hey everyone, my 99LX has been shutting off immediately after the battery and oil light come on. It happened in second gear after making a turn and it also happened in 4th while cruising. The car also tends to shake prior to this happening. One time it shook about 30 seconds before it died and another time it shook about 2 minutes before shutting down. It usually takes 2 tries before it starts, but when it starts it seems fine and the battery and oil light are not on. Just to play it safe I head home immediately after this happens, and I'm not using the car anymore until I can get it worked on; but I wanted to gather some ideas here first.
Old 08-12-2014, 06:13 PM
itburnswhenIP's Avatar
the oil light indicates low oil pressure and should immediately be shut off to prevent engine failure. you should never keep driving if the oil light stays on.
Old 08-13-2014, 05:51 AM
It is normal for the battery and oil lights to come on whenever the key is on but the engine is not turning.
Check for codes in the ECU. Likely there is a sensor that works intermittently and the ECU may have detected the problem.
Sometimes the ICM (module in the distributor that drives the coil) will stop working when hot and cause the car to stall, but when it is that you usually need to wait several minutes for it to cool off before the car can be started again.
windsor
04-28-2013 07:19 PM
hai_kichaa
11-26-2008 07:44 PM
oilltd
06-10-2008 04:06 PM
kixo
12-07-2007 09:25 AM
Quick Reply: 99LX dies after battery & oil light come on
