Alignment Problem, Need Help
Old 05-23-2010, 08:03 PM
ajjaaron's Avatar
Default Alignment Problem, Need Help
I have a 1998 ex coupe. I took my snow tires off a week ago and the right side tires are really wearing bad. I took the car to local Honda dealership for alignment. They said i need a new knuckle, wheel bearing and wheel hub. Is this the only way to correct the alignment? Does this sound correct? I can do everything myself but the alignment. Just want to make sure these are the correct parts to order.
Old 05-23-2010, 08:19 PM
We don't know, because we don't know what's wrong with your knuckle, wheel bearing, and wheel hub. But if there's a problem with them that requires replacement, that would cause a problem with your alignment.
Old 05-24-2010, 10:34 AM
ajjaaron's Avatar
This was what Honda told me to replace to correct the alignment issue. Just seems strange to me. I guess there is no adjustment on the front end. So the only way to correct is with new parts. I wanted some expert advice before purchasing the parts.
Old 05-24-2010, 11:30 AM
The only adjustment in the front would be toe. You can usually brute-force yourself a tenth of a degree or so of camber, but not enough to correct an issue.
I don't see why they'd be replacing your knuckle, though, unless you smashed the crap out of a curb.
Old 05-24-2010, 03:34 PM
ajjaaron's Avatar
Yea they asked if the car had been in an accident but that is not the case. I am the original owner. Then asked if I hit a pot hole. Sure but don't recall. I cannot see any tweaking of the knuckle. Looks fine to me but I guess it could be just slightly bent. I guess this is how Honda would get the alignment to specs. I there a good online parts place to get parts?
93ex4door
07-10-2009 07:43 PM
98hondacivicLX
04-07-2009 04:36 PM
rossimon13
13
01-01-2008 10:21 AM
SITNLOW97
03-15-2006 08:33 PM
grncivicvtec
12-24-2004 03:40 PM
Quick Reply: Alignment Problem, Need Help
