A/c clutch
A/c clutch
Does anyone know where or have seen JUST an A/C Clutch for a 90 Civic LX sedan with factory air? Back in the 90s the air was a dealer add on but factory parts.
I can find a complete compressor for around $300+ but I don't want to spend the money to change out the whole compressor & change over to R134A from R-12. When all I need is a new clutch.
Thanks
Thanks
I bought one a few years ago I think it was from NAPA. Check the label on the compressor, parts catalogs show two compressors being used but I think nearly all of them in the US market were Sanden.
I assume you're doing this because the pulley bearing is bad. As far as I know, that bearing is not sold separately. If the parts of the clutch are OK but it won't pull in, you can usually fix that by taking shim washers out to reduce the gap.
Do they make a shim kit & if so where.
I'm hooked up with NAPA Prolink & I don't see anything but complete compressors & bypass pulley.
Thanks.
VXHatchHero
06-13-2010 09:42 AM
NIKE H34D
01-05-2009 01:04 PM
addiction2bass
04-13-2008 05:19 PM
jtvision
01-11-2007 07:58 AM
HARI.
10-08-2006 09:46 PM
