'99 Civic LX intermittent misfire
Hello, I have a 99 Civic/auto with a misfire issue. Ive researched relevant threads on this topic and tried most of the fixes, but no result. I was hoping perhaps someone here could give me some fresh ideas.
The car starts fine, but there's an intermittent stumble in the idle about every 15-20 seconds. When you drive it, it hesitates/stumbles off-idle and you can feel it misfiring/hesitating a little bit at cruise. When you accelerate it stumbles before it downshifts and pulls away...once you get past that stumble, it pulls OK - until you settle into a cruise speed and you feel that little hesitation again. Sometimes, from rest, it stumbles severely but I can usually feather the throttle and get it past that. Once in awhile it will stumble enough to die, but it always cranks right back up.
Codes are:
1. O2 sensor #1 bank
2. Cat converter efficiency below normal #1
3. MAP sensor
4. IAC valve
5. Cyl #1 misfire
6. Cyl #2 misfire
7. Cyl #3 misfire
8. Cyl #4 misfire
I have:
1. Replaced plug wires
2. Cleaned IAC valve
3. Cleaned throttle body
4. Verified injector firing
5. Replaced distributor
6. Verified spark to plugs
7. Checked timing
8. Replaced fuel filter
9. Replaced O2 sensors
The timing belt was replaced about 5k ago.
Nothing's helped. Any ideas out there? Its extremely frustrating.
Thanks!!
Codes are:
3. MAP sensor
4. IAC valve
5. Cyl #1 misfire
6. Cyl #2 misfire
7. Cyl #3 misfire
8. Cyl #4 misfire
I have:
7. Checked timing
Thanks!!
Brian
03-01-2008 05:18 PM
90civic8man
12-17-2007 03:39 PM
ParisDakar
12-27-2005 12:38 PM
importmech
10-14-2004 09:25 PM
