Car Cranks But No Catch
Old 08-29-2013, 12:10 AM
SchwabVang's Avatar
Default Car Cranks But No Catch
Been having issues with my 97 Honda Civic Dx, I crank the car but the car doesn't want to seem to catch.
- Distributor has been changed
- Alternator has been changed
- Starter has been changed
I checked for sparks from my spark plugs and it gives off a strong blue spark.
I then checked for the main relay to humm when the car is in start position. Everything seems to be working correctly. I also went through my fuse box and check all the fuses and they all seem to be still intact. I went to my last resort and that was for me to go buy starter fluid and spray it. Nothing still happened.
I'm starting to lean towards that I should check the compression or else, maybe my fuel pump isn't good anymore.
Any advice would be appreciated!
Thanks.
Old 08-29-2013, 05:16 AM
Yes you should check compression and cam timing. Not firing the starting fluid could be because there's bad timing, no compression, or because the cylinders are flooded with gas. Do the spark plugs get wet with gas?
If it were a no fuel situation, it is simple to check for fuel flow by disconnecting the return hose that goes from the fuel pressure regulator to the metal line on the firewall that goes back to the tank. You should get a good flow of clean fuel out of the regulator whenever the pump runs. Testing on the return side instead of at the filter proves that the pump can develop full operating pressure and open the regulator.
Old 08-29-2013, 09:38 AM
SchwabVang's Avatar
Thanks, I will be checking on all of those things today. The spark plugs do not get wet or do I smell gas coming from the cylinders. I checked the fuel by loosening the fuel rail and watching the gas spray out strong. So i'm not leaning towards it being something with a fuel but something I will keep in mind. But thanks.
Mecca8383
03-31-2014 05:15 AM
civicvti
07-01-2007 08:46 AM
jerry814
26
02-14-2007 07:59 PM
black99ta
08-02-2005 05:24 AM
ollie
05-06-2005 10:18 PM
Quick Reply: Car Cranks But No Catch
