Possible Bad Axle
Possible Bad Axle
I Have a 92 h22 eg. I did all the work myself and I use it as much as my prelude. It is a little heavy but I have H&R drop springs and Im running tires that are to big on the car N E way. The only time I scrape is when my 300lb friend is in the car and I hit a hard corner. I did all the work myself and I didn't have that much trouble with the swap. Here are my dailies.
if you have any ideas, any ways to keep the shell pretty strong?
uh, idk..., maybe a full tien suspension?
because right now, its my only car to drive and i need to fix the problem asap.
this vid doesn't help much, but if anything looks strange, feel free to tell me.
http://www.youtube.com/watch?v=N3675B8j3Dk
Quick note for everyone: This post was moved from another thread, hence the quote. Ignore the quote since I don't feel like editing it out.
OP, if it's only when you're in gear and on the gas (meaning it doesn't do it in neutral or during coast-down), I'd say it's most likely an axle. Also, are you lowered at all?
I can guarantee the chassis isn't a problem unless your car has been wrecked. The coilovers won't fix the problem.
well got any ideas for better car maintnence?
Last edited by TH22A1; 03-15-2010 at 09:00 AM. Reason: forgot to put something in the quote/reply
they seem fine.
why? what could help if i checked the motor mounts?
Sorry for all the questions, still new to this hobby, so im basically a newbie with little knowledge.
but im open to all answers, feel free to tell me anything.
kz391
11-23-2011 05:22 PM
anibis
06-24-2011 08:55 AM
JD101
12-05-2010 08:25 PM
CID Vicious
12-11-2008 06:13 PM
addiction2bass
09-22-2007 05:54 PM
