Converting my 95dx auto to stick
RE: Converting my 95dx auto to stick
i never done one my self but its a honda how hard can it be..lol
heres what you need.
92-95 hydro trans
ecu for a manual trans 92-95
shifter linkage 92-95 maybe 88-91 also ???dounble check
pretty sure the axles are the same??
master cylinder for the clutch
pedals assemley from a 92-95 manual
hydro lines 92-95
flywheel and clutch ect..
i think thats every thing, ??pretty sure
good luck buddy
92-95 hydro trans
hydro lines 92-95
good luck buddy
Hey here's what you need:
92-00 civic d series 5 speed transmission
starter
clutch/ flywheel
pedal assembly (gas , brake, clutch)
Shift linkage
Shift ****
Shifter
Master cylinder
Slave cylinder
hydraulic lines
transmission mounts
manual ECU is optional: https://www.hondacivicforum.com/m_295187/tm.htm
(you can wire you auto ECU to be manual)
For pictures of all the parts check this: https://www.hondacivicforum.com/m_395875/tm.htm
I'm selling the setup today (fingers crossed).
starter
clutch/ flywheel
Shift linkage
Shift ****
Shifter
Master cylinder
Slave cylinder
hydraulic lines
transmission mounts
ORIGINAL: danomatic93
starter
clutch/ flywheel
Shift linkage
Shift ****
Shifter
Master cylinder
Slave cylinder
hydraulic lines
transmission mounts
starter
clutch/ flywheel
Shift linkage
Shift ****
Shifter
Master cylinder
Slave cylinder
hydraulic lines
transmission mounts
kyle4543
05-30-2005 08:10 PM
