Coolant Temp Sensor
Old 07-30-2010, 07:37 AM
slowcivic's Avatar
Default Coolant Temp Sensor
Can someone tell me where the Coolant Tempature Sensor is located on a 1991 Civic Hatch std. Is it on the engine or on the radiator. I would like to replace it to see if it fixes an idle problem I am having. Thanks
Old 07-30-2010, 07:45 AM
It's screwed into the head below the distributor. The sensor that drives the ECU is the one with two wires closer to the front (exhaust) side. The one near it with one wire only operates the temperature gauge on the dash.
asechrist
12-20-2008 10:59 PM
fglaustin
03-27-2008 08:29 PM
packman5280
02-12-2008 07:46 PM
n8te81
16
07-06-2007 06:16 PM
NewClimber
05-14-2007 05:19 AM
Quick Reply: Coolant Temp Sensor
