Couple Disc Brake Questions
Hey,
Just changed rotors and discs all around for my old man on an 04. He doesnt really take care of the vehicle too well. A lot of rust and corrosion. When I took the slider pins out some of them were seized in there pretty good. I was able to wiggle/pry them out. I replaced them with new pins and cleaned them out as best as I could. The dust boots were in pretty rough shape. I replaced some of the boots as well but I couldnt get the boot to attach back to the caliper bracket in the lip to seal it back up due to corrosion and rust.
My questions are:
-How do you effectively clean out the hole for the slider pins?
- How big of a deal is it if the slider boot doesnt sit in to the mounting bracket hole?
- What type of grease/anti seize do you use for the backs or notches on the pads.
Thanks for your help guys, I appreciate it.
BertW
My questions are:
BertW
Hi BertW. The link below covers the topic "How to service your brakes if you live in an area with snow", or in other words, rust.
INTRODUCTION: Brake servicing in snowy areas
If the pins or calipers are badly rusted you may be better off replacing those parts. If you decide to clean them use as gentle a method as you can that accomplishes your goal. The above link provides several options for cleaning out the caliper bores. Once you have smoothed the surface clean it thoroughly with a brake cleaner spray.
If the caliper pin boot doesn't fit tightly then you will have environmental contaminate/corrosion problems much sooner.
For the backs of pads, anti-squeal shims, and pad "ears" I use a high temperature brake grease such as CRC Brake Caliper Synthetic Grease or 3M Copper Anti Seize Brake Lube. For the caliper pins I use 3M Silicone Paste or Sil-Glyde Brake Lubricant.
Ska-T, I really appreciate your answer. Thanks a lot man! Very helpful
honvic
03-13-2012 06:28 AM
