Cylinders misfireing
Old 06-04-2009, 02:23 PM
blazz's Avatar
Bingo!!, thank you mk378 for confirming that, the fan did come on with a jumper,
I wonder how much this little sensor is going to cost me.
I already knew the valves need to be checked when the car is cool, and my maintenance book explains which way you turn it,,
My only problem with the valves are I only have millimeter feeler gauges, I used a inch two MM converter that I found on the Internet.
The book calls for .007 -.009 on the intake and.009-.0011 on the exhaust,
.007 = .1777mm
.009 = .228mm
.0011 = .02794mm <--some thing is not right here my book maybe wrong should be .011 right??? = .2794mm
So for the intake I have .20mm and for the exhaust .25mm
If I'm not mistaken this should work... both numbers fall in the middle.
I plan on doing this first thing in the morning but I will wait until someone confirms that this is OK to use.
I am going to get that temperature sensor, and a cylinder pressure tester, the shop wants 40 dollars to do it and I found a tester for 30, so I'm just going to do that myself, I'm sure I can find info on the correct way to do it in these forms.
Thanks again guys.
saturn78
04-19-2007 01:36 AM
shockermotorsports
04-14-2007 07:54 PM
SpoonStar@10000rpm
EG Swaps
06-14-2006 07:03 PM
RiceBurner
02-06-2005 04:40 PM
RiceBurner
01-16-2005 09:09 PM
Quick Reply: Cylinders misfireing
