Dashboard gauges/lights go out but car keeps running!!??!! Help please...
Was drining and then everything goes dead on the dash...cars still running fine...then, voila, dash back on. Drive home fine. Next morning (and passing the same spot!!!!) SAME THINKG happens! Thinking X-Files stuff here but any other answers? Thanks guys...
RE: Dashboard gauges/lights go out but car keeps running!!??!! Help please...
what was the area taht you drove through?? was it just an open area, or is there actually something there? like a production plant of some sort, or a power plant... could be some sort of crazy stuff going on in there that is causing it...
Check your fuses to see if they are OK or Loose. Also check your harness where it plugs into cluster to see if it is plugged in good.. I have also seen the circuitry on back of cluster go bad. But it is rare.
green1994civic
03-10-2012 08:03 AM
itzcorky
09-21-2011 07:45 AM
hydrocivic
04-21-2010 07:34 AM
panaphobic
05-08-2008 10:47 AM
macbubba
04-07-2008 05:49 PM
