DIY Timing Belt Install - HondaCivicForum.com
Reply
Old 08-07-2007, 05:55 PM
Default DIY Timing Belt Install
I have a 2001 Civic DX-G, I was thinking about changing the belt and water pump myself. I have plenty of experience working on cars, I am a former autobody repairman. I have a Haynes manual for this car and after reading the general procedure I'm thinking I'd be able to tackle this job myself. I'd change the cam and crank seals along with the other belts for the power steering, ac, and alternator. How long does such a job usually take for the backyard mechanic? Thanks, Brian.
Old 08-07-2007, 06:27 PM
Default RE: DIY Timing Belt Install
This is just a guess, but if I go ahead and put it someone that knows will correct me and you will get your answer. LOL
I would say about six hours tops?!?!?!?!
Old 08-08-2007, 02:26 AM
Provided you have all the tools, enough space to work, and maybe a friend to help you with a few odds and ends you could do it in a night. I would definitely give yourself a couple days though, you never know what you're going to run into during a swap
Old 08-08-2007, 04:45 AM
gsumano's Avatar
^^^yeah, give yourself at least 2 days. I broke two extension sockets when trying to take out the cam pulley bolt off[&:], good thing craftsman has life time warranty
Old 08-08-2007, 04:54 AM
I think I posted that in the wrong thread, for some reason I thought this one was about a swap [&:] ownd by not reading...
anywho, still give yourself a solid day or so to do it.
Old 08-08-2007, 06:44 AM
Having an impact wrench for the crank bolt and motor mounts makes the job a lot easier. If you're doing this outside be very careful as you take the crank pulley off, not to lose the tiny metal key.
I would not mess with the oil seals unless they're leaking. It's easy to damage the new seals while putting them in and then have them leak and have to do the whole thing over again.
Old 08-08-2007, 10:51 AM
Thanks for the replies, I have the tools, compressor, and a garage.
Old 08-08-2007, 02:43 PM
See I told you it would work. ROFLMAO!!!
Reply
Thread Thread Starter Forum Replies Last Post
Timing Belt and Gasket DIY droopy128 Mechanical Problems & Technical Chat 4 04-13-2012 10:34 PM
DIY Timing Belt Faithbleed Mechanical Problems & Technical Chat 2 07-26-2010 10:23 PM
procedure for changing serpentine belt/timing belt on 01 civic ex pippo Mechanical Problems & Technical Chat 5 01-26-2010 02:40 PM
DIY Timing Belt 2ManyTickets Engine & Internal 7 02-26-2009 10:25 PM
DIY timeing belt & accessory belt change thakid Engine & Internal 1 01-30-2006 08:29 PM
Tags
2000, 2001, 2005, 7th, belt, change, civic, diy, extension, gen, honda, install, lx, pump, timing, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
