does my o2 sensor effect my car's performance (d16z6)
RE: does my o2 sensor effect my car's performance (d16z6)
the o2 sensor controls the air fuel ratioso if u go in depth with it i guess u could say it does effect it. if ur car is running lean it will tell the computer to richen the mixture and the same thing if its rich
ORIGINAL: mosagalzeta
does it effect my performance ? & please tell me it's function?
http://www.aa1car.com/library/o2sensor.htm
ORIGINAL: RonJ
Absolutely, by precisely determining the amount of oxygen present in the exhaust, the O2 sensor (in conjunction with the ECU) allows the engine to run at the stoichiometric air/fuel ratio (=peak performance).
if you are not getting enough oxygen then you are car will start to use more fuel. Like Ron said there is a certain stoichiometric ratio that must be met, and if one is decreasing then the other has to increase
Specialbrownie
05-02-2010 07:38 PM
SilverWrench
05-08-2008 08:35 PM
