Driver Side Windows Clicks and will not roll all the way up.
Well, it appears that the late 90's model Civic have some issues with their d-side window assemblies or something. About a month ago my start clicking when it got toward the top of rolling it up. It is automatic so I just started helping it up at the with my hand. It has progressively gotten worse. Now it will only roll up to part of the way and there is about a 1 inch gap left open.
I took the door panel off and it appears the (what I guess is) the sector gear on the regulator. From looking at some exploded views of the door that is the best terminology I could come up with.
Basically the gear part that connects the motor gear is the issue. A few of the teeth on the gear are worn causing it to slip.
Does anyone know if I can just buy the sector gear or do I need to guy the while regulator arm?
thanks in advance!
.m.
thanks in advance!
.m.
Yeah, replace the entire regulator. It's a DIY job. The hardest part is taking off the door panel, which you have already succeeded in doing. The next question is why did the gear strip. You may want to spray some silicone lubricant into the rubber side channels for the window to prevent this from recurring.
It's all riveted together. You buy the whole part #1 or #3 as a set. Note of course they are different (mirror image parts) between the two sides of the car. The driver's side is usually more of a problem because it gets opened and closed a lot more.
When putting the motor on, make sure the motor gear is fully engaged to the sector gear. You don't want it running just on the tips of the sector gear teeth, the tips will strip off. The motor gear is hardened steel so it should not be worn or stripped compared to the soft stamped sector gear, but inspect it. Finally, apply grease to the gears.
Thanks
Thanks for the reply guys... It's sometimes hard to tell looking at the exploded views to figure out what is what.
The site I got the picture from labels this parts as a (pt # 72275-S03-G01 - CHANNEL, L. FR. DOOR RUN) I guess the whole part would be #13, right?
http://www.hondaautomotiveparts.com/...y5=DOOR+WINDOW
I've never ordered from this site before. Anyone point me to someone they have used or would recommend? or do you think I could get it local at a Napa or something like that?
I ended up getting the part off of ebay for about $27 - $37 shipped (aftermarket brand). Took me about 45 minutes to replace. was very simple and I am not a mechanic by no means. If you have any abilities to repair things then it should be easy for you as well.
I would think it would be at least a couple hundred if you took it to the dealer.
