DRL turn off when parking break released
Hi there!
I own an 03 Honda Civic Sedan... but
When the car is off, or when the parking break is engaged (on startup), the daytime lights and high beams work properly.
Although, when the car is running and the parking break is released the daytime running lights turn off and the right beam turns on. The dash "DRL" light is also on.
(i hear a relay click at this point)
Hope someone can help! Is there a light sensor? Or is this a bad DRL board?
Thank you
Thank you
I had the Same issue about 3 weeks ago... except to make the DR light go away I would just need to turn my headlights on. After dealing with that for a few months.. I just got out the car to check out the situation when the DLR light came on "usually as soon as I release the parking brake" so a checked out the lights... one of then didn't work....went to pep boys got a new headlight...( Not a High beam) problem solved. 2006 Civic si 2 Dr coupe
KFRG
02-07-2010 03:28 PM
dlion77
01-23-2010 09:03 AM
