Filters and Coolant 1.8L 2014
Old 08-03-2014, 05:28 PM
Timbogates's Avatar
Default Filters and Coolant 1.8L 2014
Do you know of a good link for a service manual? Also what is a good grade of coolant to use in the 1.8L Civic? 2013. What has happened to all the antifreeze coolant (anti rust / water pump lubricants) you can add to the fresh antifreeze on a change?
What are good quality air filters? Honda only or who else would be high quality?
What about oil filters??
Old 08-04-2014, 09:47 PM
itburnswhenIP's Avatar
01+ honda's should only use OEM honda coolant you won't need additives if you use honda fluid its designed for honda engines. napa filters will work along with most generic drop in filters anything is better then a clogged dirty filter. i wouldn't use K&N those require oil which can gunk up sensors. the best would probably be AEM but im not sure if they make drop ins for your year.
funkcity
09-25-2014 02:23 PM
Hondaadnoh
02-09-2014 03:06 PM
paak
14
11-19-2011 02:24 PM
PonDaCivic
06-14-2009 05:07 AM
civicpimpinsc
12-22-2006 08:40 PM
Quick Reply: Filters and Coolant 1.8L 2014
