Finally got car running after timing belt change, Now no power and exhuast sounds alot differnt
Old 01-31-2008, 09:46 PM
dave_57204's Avatar
Default Finally got car running after timing belt change, Now no power and exhuast sounds alot differnt
Hey, I finally was able to get my car to start damn timing belt was a off a tooth. Now it runs fine sorta. I don't have any power like I used. Which I think could be ignition timing, and for some reason my exhuast sound really differnt, any ideas on that one? And one more thing. Idleing is messed up, It idles fine, then sometimes if you press on the gas and let it go it idles at 1.5-2k press on the gas again idles arond 1200, then back to normal. very werid.
Old 02-01-2008, 06:10 PM
Default RE: Finally got car running after timing belt change, Now no power and exhuast sounds alot differnt
Start by making sure the timing is set to specification.
Old 02-01-2008, 06:43 PM
well if it didnt run before i guess that it was 2-3 teeth off... my belt was at least 1 tooth off but it would still run just horible reaction when i punched the gas....
changed the belt over another tooth as well as timed it and still runs great to this day
Old 02-01-2008, 08:07 PM
dave_57204's Avatar
Yea, When I floor it, It pushes me back in the seat a little bit but not like before and it seems sloppy. You guys think its the timing belt or ignition? Also I fixed the idle was a leaking vacum line. Still stumped over the exhuast sounding ALOT differnt.
Old 02-01-2008, 08:16 PM
Have checked the engine timing as described in the picture?
You need to describe the abnormal exhaust sound.
Old 02-02-2008, 11:17 AM
dave_57204's Avatar
I took it up to the shop, they said its the timing belt its a tooth off. there gonna fix that. Now the exhuast was semi deep for a honda. I have 2 resonaters and a option racing muffler. Now the exhuast is alot more higher picthed almost like its overreved, but its not. thats the best i can explain it.
Old 02-05-2008, 08:14 AM
dave_57204's Avatar
Ok I think I may have figured out why my exhuast is sounding like ****. My car was backfiring, mabye that destoryed the inside of my muffler? I'm gonna go take alook later.
Dee911
07-21-2011 10:32 AM
snosurfa7
03-07-2011 05:56 PM
vltnolia
06-29-2008 07:07 PM
dave_57204
01-27-2008 10:16 AM
redgst
03-28-2007 07:37 AM
Quick Reply: Finally got car running after timing belt change, Now no power and exhuast sounds alot differnt
