head unit install
Old 11-14-2007, 09:36 AM
gomorig's Avatar
Default head unit install
i have a 05 civic lx special edition. it has the 6 cd changer in dash but i have a system that i want to replace it with.im having trouble finding how to get my dash apart and the cd changer out. ive found info for other models but not mine. can anyone help?
Old 11-14-2007, 10:06 AM
Default RE: head unit install
umm, nevermind. I thought you said '95.
Old 11-14-2007, 06:08 PM
Civic Si 00's Avatar
Try http://www.crutchfield.com/ they might have the info how to remove your stereo. Good luck buddy [&:]
Old 11-16-2007, 07:12 AM
cmfmets's Avatar
Yeah, Crutchfield makes master sheets for almost all makes and model cars. They send them with any order you make with them but I believe that you can get them separately also. These will tell you exactly how to get the dash apart adn then back together, good luck!
- Craig
Old 11-17-2007, 03:20 PM
sto73's Avatar
i just changed mine out in my 01 civic today. its easy once you do it. down where the cigarrette lighter plug is , pop that whole panel out , it just clips in. underneath theres two phillips head bolts. pull those out and the whole center dash console will pull straight out. pull it out as far as you can and unplug all the plug in harness clips and your ready to go.
TheFranchise2k5
04-18-2008 08:48 PM
Rmw125
02-26-2008 07:41 AM
megafandrew
02-10-2007 06:24 PM
aprice
09-09-2005 07:31 PM
ohbiskits
06-22-2004 02:13 PM
Quick Reply: head unit install
