Fuel Gauge won't work :(
The gas gauge is on the same fuse as the speedometer and the temperature gauge. So if those work, it's not the fuse.
You should be able to disconnect the wires back at the gas tank (access by taking the bottom cushion of the back seat out) and check the sender with an ohmmeter. It's pretty much standard that full is 0 ohms, empty is 40 ohms, so half full would be about 20. If you ground the wire that leads to the gauge and turn the key on, that simulates a full tank so the gauge should go to full.
codex89
06-20-2011 10:31 PM
Faramire
09-07-2009 02:27 PM
siwel177
12
07-17-2009 06:47 AM
