fuel help
Are the spark plugs firing? If the ECU is not running or it thinks the engine is not turning, the injectors will not open. Double check the ECU grounds on the thermostat, also check for CEL to cycle on then back off when you turn key on but don't crank. Is it wired properly? The OBD0 MPFI setup (1990 Si etc.) needs an injector resistor pack.
CivicEX2006
09-20-2007 03:32 PM
4doorcivic9
07-11-2007 10:54 PM
TheBlackCivic
07-16-2006 11:45 AM
nightrider46
08-23-2005 03:42 PM
