fuse keeps blowing
Old 08-10-2007, 09:13 AM
cbaber's Avatar
Default fuse keeps blowing
Well the other day I got in my car and went to turn on the lights, and the gauge cluster lights didnt turn on. I checked the fuse and it was blown. I replaced it and tried again. It blew again. Then to make sure I tried a 3rd one. Blew that one too. I even tried replacing the cluster. The fuse is for the taillights, panel, and license plate lights i think. Any idea whats wrong? BTW its a 1995 civic DX.
Old 08-10-2007, 09:50 AM
Default RE: fuse keeps blowing
Short circuit to ground somewhere. Buy a bunch of new fuses and try disconnecting stuff until the fuse holds, the short must then be in a part that is disconnected. I think the lights can be unplugged in the trunk. Also disconnect the yellow lights on the front corners. You can isolate the panel lights by unplugging the dimmer unit on the dash.
Unfortunately this is often caused by damage to one of the wiring harnesses, which requires taking a lot of stuff apart to get at the harness for a visual inspection. Fortunately it is constantly shorted. An intermittent short can be almost impossible to find.
Old 08-10-2007, 12:35 PM
AgentofDarkness's Avatar
Instead of buying a bunch of fuses, hook up a test light in series with the fuse. Start unplugging stuff. The light will stay on until you unplug the part that is shorting.
Old 08-11-2007, 02:21 PM
cbaber's Avatar
K thanks for the help guys but I figured it out. It was this orange wire from the factory stereo connector thing that kept shorting out. Just had to unhook it and tape it up.
bigmikew1
41
03-15-2010 09:33 AM
RoadRacer
05-20-2008 07:38 AM
tpfoudray
03-03-2008 04:29 AM
Stocker
12-05-2007 05:53 AM
caution2008_mpw
06-16-2007 09:48 AM
Quick Reply: fuse keeps blowing
