Is it hard to replace caliper? (I change my own oil.)
Old 04-21-2017, 04:18 PM
DaHonDa's Avatar
Default Is it hard to replace caliper? (I change my own oil.)
Hello,
I have a 1995 Civic Lx. A mechanic who inspected my car says my front-right caliper needs to be replaced. Is it hard to do? I change my car's engine oil myself to save on money.
Old 04-22-2017, 11:06 AM
You shouldn't have a problem if you know how to turn a wrench. Remove wheel, remove 2 bolts (14mm) on the back of the caliper and bolt the new one on. You will need to bleed the brake system. While you are in there, you could remove the 2 17mm bolts holding the bracket and regrease the slider pins.
This would be a good time to swap in new pads and rotors, depending on the condition of your current brakes.
oilltd
06-10-2008 04:06 PM
dcdenonda
02-28-2007 07:36 PM
mill$civic
11-09-2006 02:58 PM
Patrick
04-24-2006 06:37 AM
Quick Reply: Is it hard to replace caliper? (I change my own oil.)
