head back on now oil comming out by intake?
Old 08-26-2012, 11:31 AM
rcgtsport's Avatar
Default head back on now oil comming out by intake?
i just did head job on my 96 ex. i started it up know oil all over intake is there a plug maybe machine shop took out or is head gasket upside down. looks like no oil reached under valve cover when i looked in oil fill. i just walked away from it what should i do or look for?
Old 08-26-2012, 12:04 PM
Is it from the VTEC solenoid? The gasket between the solenoid and head can blow and cause a major oil leak.
There's only one oil feed through the head gasket, the passage in the back center. There should be a metal ring in the gasket around it. I don't think it is possible to put the head gasket on the wrong way, nothing would line up.
Old 08-26-2012, 03:05 PM
rcgtsport's Avatar
went back and took intake off there is a hole in head but dont looks like theres threads to bolt a plug to? its in the center .
Old 08-26-2012, 03:29 PM
rcgtsport's Avatar
could it be like push in plug? or something under valve cover?
Old 08-26-2012, 06:58 PM
MBrent's Avatar
July 2010 ROTM
Pics would help sir. Is oil IN the intake or just leaking from around it? Is your pcv valve in good shape?
Old 08-27-2012, 04:41 PM
rcgtsport's Avatar
it turns out machine shop left a little round ball that plug a hole. they came to the house to hammer that little thing in. weird i'll found out if it works tommorow in the day light. thanks for input!
oilltd
06-10-2008 04:06 PM
jimcope
03-24-2008 07:33 PM
Fiirkan
05-08-2006 07:22 PM
foozball
08-12-2004 08:18 PM
Quick Reply: head back on now oil comming out by intake?
