Heater not blowing alot of air!!
Old 12-26-2009, 11:32 AM
sketchen's Avatar
Default Heater not blowing alot of air!!
ok so its been a while since my last post but here is my issue:
when I turn on my heater after the engine is at normal temp i turn to full heat and i can hear the fan working but the defrost setting barely blows any air at all if i switch to cold it blows alot. also if i switch to the foot setting it blows more air than defrost and so on ive pulled it all apart and cant see anything wrong yet... without tearing all the ducting apart i have a 1990 civic if anyone has any ideas or if this is a common problem please help
Old 12-26-2009, 02:00 PM
If you don't have air conditioning, it's pretty simple to remove the duct between the fan and the heater box (installed behind the glove compartment where the evaporator would be if you did have A/C). From there you might be able to see if the heater core is clogged with leaves, etc. Also check that the air doors are actually moving like they should when you move the controls on the dash.
Kadels2
03-04-2016 10:07 AM
Dee911
07-21-2011 10:32 AM
rohan076
05-17-2011 08:24 AM
CrunchyToast
02-16-2011 10:37 AM
tgs
03-28-2010 07:12 PM
Quick Reply: Heater not blowing alot of air!!
