Heater Problems
Old 02-11-2013, 06:07 AM
walter duque's Avatar
Default Heater Problems
Hi to everyone. First time poster here.
I have a 2005 Civic EX which I have a heater problem with. Heater blows cold air even after starting and let run for an hour. Temperature gauge goes up to normal. Antifreeze is good. Heater will blow hot air after I rev the engine a few times. What could be the problem? Thanks for any help.
Old 02-11-2013, 01:41 PM
This sounds like there is not enough coolant. Check the level in the radiator itself, it should be full to the top. Do not just check the white plastic tank.
Old 02-11-2013, 01:45 PM
Coolant is good. Did fill the radiator, even jacked up the front end to make sure the radiator is full of coolant. Could it be a clogged heater coil?
Old 02-11-2013, 03:33 PM
It could, you can disconnect the heater hoses at the engine end then flush the core forward and backward with a garden hose. Dash dial must be set to full hot, engine not running of course. Also check that the valve on the firewall moves all the way when you turn the dial.
tgs
03-28-2010 07:12 PM
gandalf386
02-09-2009 04:32 PM
jrestrepo589
12-26-2008 03:41 PM
romic00
12-03-2006 08:06 PM
NorCalRice
02-13-2005 04:48 PM
Quick Reply: Heater Problems
