help bleeding coolant system 95 civic ex
Okay so I replaced the 02 sensor and the radiator and the thermostat and the CEL is finally GONE!! (YAY!!)
In order to get the sludge out of the coolant system, I am trying to flush it before filling with the new stuff so I don't just ruin the new radiator but I can't seem to get the bubble out of the system and from what I can tell, there just isn't any water going through the lower radiator hose to the thermostat - all other hoses are hot but that one and there seems to reference to a bleed screw somewhere which I cannot identify on the car - anybody got pics or a diagram where i might find it or an alternate method of getting the air out?
heat comes on, but I've not seen the radiator fan move yet - should I run it with the heater on or off until the fan kicks in first?
Any help would be appreciated as I really don't know what I am doing and can't afford to take it to the shop. So far, I do okay following guides and instructions from the helpful folks like you all!
You need to idle for a long time before the radiator gets hot.
The bleed bolt is in the fitting where the top radiator hose attaches to the engine. It looks and works like a big version of the bleed bolt on a brake caliper. If your engine has been swapped to a later model you may not have one. In that case, run the engine with the radiator cap off to bleed it.
56kz2slow
04-10-2005 07:00 PM
