help me please
help me please
i have a 02 civic ex110K, Radiator1 yr old new waterpump and timing belt 1 mo old,All hoses checked for leaks I live in hawaii and my mechanic said no need for a thermostat so i said take it out thus no thermostat. Radiator 50/50 h2o and rad fluid..He has looked it over 3-3 x but it keeps overheating. If in stay under 60mph it goes 1/8 "under middle on gauge.Before i had this problem it was always at 25% or less from cold.I drive 43 miles to work first 12 are 35mph no problem..Then next approx.31 are highway speed limit 55-60.When i go 70 it overheats in seconds. As long as i stay around 55-60 it is ok but if there is a traffic jam or backup it will overheat in minutes. i thus must turn it off when ever i can in the traffic to cool and cars in back do not like that.Can anyone tell me what more i can do to stop the overheating.. I am at my wits end. All hoses are good as is circulation and there are no leaks. My A/C is broken so do not use that and when i run the heater it at times will bring it down maybe 1/8" but very little and dammit it is hot overhere and by the time i get to work i am a sweatball with the heater running for 1 hour..Thank you for any help you can give me as my mechanic cannot think of anything else..I noticed the ECD light comes on once in a while could that be any thing with it..We have no emmission control checks here in hawaii so i dont care to get it replaced if it goes.Thank you again for any help I forgot to add on my way home last night heat gauge was in middle then first time this happened I had pulled into a 7-11 and car was still hot when i went to drive away after car being off for maybe 5 min..Gauge went down almost to very bottom to cold maybe 1/8" from bottom of cold scale.,Stayed there for a few minutes then went back up to hot..I never checked the hotness of radiator when it reads HOT but could there be something wrong with the actual dash heat temp monitor ??? I just cannot think of anything else...PLEASE HELP
Last edited by sharonmil@hotmail.com; 05-10-2015 at 01:57 PM. Reason: I forgot something
Whenever the light comes on you should scan the code just to know why.
Removing the thermostat, as you have found, seldom solves anything. The engine will get better gas mileage and last longer if it warms up to design temperature and stays there by the action of the thermostat.
Is the radiator staying full? Check it when cold before each trip. This is in the radiator itself don't just look at the side tank. If you keep losing fluid out of the radiator the head gasket may be leaking. Also if a "stop leak" agent has been used it could have clogged up the radiator.
help again please
That is typical for a slow leak in the head gasket. You see bubbles in the radiator when you start the engine cold and rev it. This gas will displace the coolant into the bottle and it doesn't come back, leading to overheating. There are no other symptoms of a small leak.
DontHateOnEG8
20
09-06-2008 06:49 AM
