help me please...im going crazy
yea i figured thats what was happening..i have a replacement but its not going in till i either replace the thermostat housing or drill and tap the existing one..could a bad O2 sensor cause the problem..heres my real question..can a sensor be bad and not throw a code?
anything can happen...
If you're getting air in the coolant system, it will make for a jerky ride.
apparently o2 sensors can go bad and not throw a code, too. heh. i didn't think that was possible. post #5 gives a tip in the right direction i think...
Can O2 sensor go bad without throwing a code? - Honda-Tech
i replaced my map sensor..just because..didnt make a change..ill try and get a reading off the front o2 sensor and let u know what happens..i know it doesnt produce a ton of voltage(mV-1v?) so what exactly should i look for?
It's only a dumb question if you don't ask it... so..
Did you swap out the ignition control module? It's another component in the distributor. I've seen some replacement distributors that came with them and some that didn't. My ICM went out at 130K miles. My sister's ICM went out at 312K miles. It's a toss up on how long they last.
It's a very easy thing to replace, but it's like $100ish at Autozone. You can remove yours and take it to autozone/advance/etc and they will test it for you. Very easy to remove, especially since you've already disassembled the thing before.
WildWildIp
05-09-2007 05:00 PM
FlipHKD720
16
03-19-2007 07:31 AM
blkwidow
07-27-2006 03:03 PM
