Help. Need to REMOVE rear view mirror.
Old 03-09-2009, 09:23 PM
danomatic93's Avatar
June 2010 ROTM
Default Help. Need to REMOVE rear view mirror.
Yeah, weird, normally it's the opposite. So, WITHOUT playing King Kong and body slamming it, hold does one properly remove a rear view mirror??
Car: 93 Civic
Thanks in advance!
Old 03-10-2009, 12:26 AM
On the base of the mirror, making an imaginary line perpendicular to the ground, there is a screw. Unscrew it and slide the base of the mirror upwards following the angle of the windshield to slide it off of the metal bracket that is glued to the windshield
Old 03-10-2009, 09:03 AM
June 2010 ROTM
thanks!!
Now, any suggestions on how to get that base off too??
Old 03-10-2009, 09:18 AM
jprommel's Avatar
Angry Admin
heat gun should loosen the glue then try using a spackle knife or something to get it off preferably plastic so you dont scratch your windshield
Old 03-10-2009, 04:08 PM
^yea and then maybe use some goo-be-gone or whatever it's called.
Old 03-10-2009, 04:59 PM
is it glued to the windshield or on the roof?
if its on the roof remove the plastic cover with a flat screw driver to pop it off and remove the 3 philips screws...
if its on the windshield they have several types, allen screws to lock it on the bottom of the windshield mount, of if no screws are visable then some use a clip that you use a scerw driver pushed up in there and turn it to release the clip and then slide the mirror mount up, but your windshield tab will still be on the windshield. just dont try to remove the metal tab on the windshield..... you risk busting the glass.... best time to remove the tab is on a VERY VERY HOT DAY and a lighter on the windshield to heat it up even more and hopefully you can pull it off and not bust the glass windshield... its still a risk tho... other way is get some hard bass and crank it up on a hot day and hopefully it will eventualy just vibrate off cleanly.LOL
very easy...
Old 03-25-2009, 07:52 AM
1995HondaCivicDX's Avatar
Default RearView Mirrior
Yep He knows his Mirriors. I was for the love of me trying to figure out how the last 1 he mentioned slid off the windshield. I origionally Bought the Honda in 1996 Its since seen 7 Years in Mass then 2 Years in the Florida Sun and then 1 year in NewHampshire It just fell off 1 COLD COLD NIGHT LOL Clean as a whistle too. Never Tried the stereo thing tho
Old 03-25-2009, 08:08 AM
June 2010 ROTM
Thanks guys, it came off with a small flat head and slid it right off. I think I'm going to leave to base there just in case I feel the need to put the stock mirror back on.
enigma34
05-22-2008 08:50 PM
mdgttim
07-05-2007 03:45 PM
Basset3
04-24-2007 04:25 PM
RedEH3
03-10-2007 10:43 AM
Samanthaxxx
14
12-15-2005 04:40 AM
Quick Reply: Help. Need to REMOVE rear view mirror.
