Need help regarding Main Relay 87 Civic
Old 09-02-2006, 06:55 AM
danielintheuk's Avatar
Default Need help regarding Main Relay 87 Civic
I have had a problem for the last few weeks regarding my civic not starting when it gets warm, it has to be cooled down before it will start. I have read a few things on here and other sites which indicate the problem is most likely the main relay . Today the car will not start at all, the battery is good, and when I turn key to 1st position I get the 2 second fuel pump noise, and when i turn it to start the engine does not turn over but I get continuous fuel pump noise, I think this means its definitly the main relay. Any comments appreciated.
My problem is I cannot find this main relay , I believe its somewhere around the fuse box under drivers side dashboard , I have pulled out a wiper relay, a relay which I presume is for indicators serial number fc257ek. and I can see in some impossible place to get to there is another relay for dim dip headlights. I cannot see a main Relay. Can anyone describe in detail where this main relay is?
Any help greatly appreciated .
Dan
Old 09-03-2006, 08:35 PM
fglaustin's Avatar
Default RE: Need help regarding Main Relay 87 Civic
there is a little holding cup in the middle dash area on the left side.
if you are sitting in the drivers seat, then straight forward of your knee-cap is the little tray - has a pull-down door on it.
all that needs to come out - and it is up behind it.
i took those little cups out to the right also.
think you need 10 mm socket - not for sure, though.
Old 09-16-2006, 07:56 PM
The main relay is under the dash, just above the hood latch lever. It's probably a grey, rectangular part.
http://techauto.tripod.com/mainrelay.htm
Old 09-17-2006, 01:30 AM
deserthonda's Avatar
i am assuming your car is the SI model correct ? fuel injected??
if so, it is where kinosh said ,,,,,,,,,
ktorres1120
09-04-2013 08:07 PM
Civic Si 00
11-10-2007 06:32 PM
hmdaigle
07-17-2006 10:41 AM
ICONOMAT
12-13-2004 10:44 PM
96EX_NC
08-18-2004 09:40 AM
Quick Reply: Need help regarding Main Relay 87 Civic
