Help replacing Igniter and Ignition coil
Old 07-08-2006, 03:09 PM
skimmy_jimmy's Avatar
Default Help replacing Igniter and Ignition coil
hey fellas, can someone maybe help me out with this? im replacing my ignition coil and igniter. to do this, is it all just right behind the Distributor cap?
Old 07-08-2006, 03:11 PM
ef4life's Avatar
Senior Member
Default RE: Help replacing Igniter and Ignition coil
it is inside the cap. just remove the cap and rotor, and then replace the parts.
Old 07-08-2006, 03:12 PM
sweet thats what i thought. thank ya much. the only part im worried about is taking the screw off that holds the rotor cuz when i replaced the dist cap and rotor it was in there pretty good, i kinad stripped the screw[:@]
Old 07-08-2006, 03:13 PM
ef4life's Avatar
Senior Member
a new rotor usually comes with a screw. put a little anti sieze on it so it will come out easier next time
Old 07-08-2006, 03:16 PM
sweet, thanx for the help ef
Old 07-08-2006, 06:33 PM
ok got er all done, if i didnt do it right, it wouldnt run AT ALL would it?
Old 09-16-2006, 02:28 PM
IS ANTI SIEZE SIMILAR TO DEEP CREEP? MY FRIEND SPRAYED THE SCREW WITH IT BUT IT WON'T BUDGE. IT IS ALMOST LIKE IT IS WELDED ON THERE. I AM UNABLE TO INSTALL THE NEW ROTOR. ANY SUGGESTIONS?
Old 09-16-2006, 08:41 PM
fglaustin's Avatar
you will have to turn the engine to get the screw on the very top and get into there with a drill and drill the head off and continue drilling to get it down to the shaft to pull the rotor off.
good luck.
Old 09-17-2006, 01:32 AM
deserthonda's Avatar
it would be a lot easier to remove the distrubutor......3 ,12 mm bolts and a couple of connectors
assuming timing is correct , mark the distributor so you reinstall it at the same spot
sledneck82
12-05-2009 09:27 AM
ORcivic
02-14-2007 07:25 PM
MarcB
01-23-2007 08:20 PM
arm97002
09-06-2006 10:33 PM
ineedhp
04-17-2005 09:50 AM
Quick Reply: Help replacing Igniter and Ignition coil
