Honda Civic Ex 2001 oil leaking problem (Contd)
Old 04-18-2015, 11:58 AM
LionSpratt's Avatar
Default Honda Civic Ex 2001 oil leaking problem (Contd)
Hi guys....my car (2001 Honda Civic Ex) has been leaking a lot of oil for a while. We have spotted oil leak from a few places, and replaced the Valve Cover seal and the rear camshaft seal. But the car still leaks a lot of oil.
Trying to spot where the leak comes from, we have spotted oil on some areas, but can't figure out where it comes from.
I've attached two pictures. The first picture is the area underneath the EGR Valve. We thought the oil coming from the bolt (I dunno how that bolt is called), but it doesn't. It drains down from somewhere above the bolt.
The second image is the area below the valve cover. As soon as you open the hood, you see that. That whole area has also traces of fresh oil.
Do any of you guys have an idea where the oil is coming from?
I'm thinking rear crank seal, but I just wanna be a little bit more sure before taking it to the mechanic.
Attached Thumbnails Honda Civic Ex 2001 oil leaking problem (Contd)-oil-leak-pic-1.jpg   Honda Civic Ex 2001 oil leaking problem (Contd)-oil-leak-pic-2.jpg
Old 04-18-2015, 06:03 PM
VTEC solenoid can leak a lot since there is oil under pressure there.
jaysdogjazz
13
11-21-2015 09:07 PM
LionSpratt
12-01-2014 08:50 PM
ic892003
20
08-21-2008 03:40 PM
oilltd
06-10-2008 04:06 PM
Quick Reply: Honda Civic Ex 2001 oil leaking problem (Contd)
