Honda Civic won't start.
Old 09-30-2012, 01:10 AM
Nephthys's Avatar
Default Honda Civic won't start.
Okay, Got a 1990 Honda Civic Hatchback with a 1.5 engine DX
It wont start. engine cranks, but it wont start up I have replaced the distributor, the fuel pump, and the main relay, and the alternator but the problem still continues. There is no spark, but the distributor is brand new. Am thinking it could be the camshaft sensor but not sure. Any ideas what could be going on? Yes, I have gas in the car, and the battery has been tested and works.
Old 09-30-2012, 09:02 PM
conceptualpolymer's Avatar
Instead of replacing things, first, you should check or have a mechanic check to see which component is causing the problem. Di you check the coil's primary and secondary resistance? The igniter can fail at 120,000 miles or so. Do you have a service manual and a multimeter?
Old 10-01-2012, 03:47 AM
Check that the timing belt is not stripped-- the cam rotates when you crank. All the rotation sensors are inside the distributor. Check that battery voltage is reaching the distributor on the large black and yellow wire.
David_S
10-24-2013 10:06 AM
jeff71601
14
03-02-2011 08:05 AM
BabyGangsta
08-04-2006 09:06 PM
eclecticanna
12-13-2005 10:21 PM
randocsmith
07-08-2005 05:53 PM
Quick Reply: Honda Civic won't start.
