Hood Release Broken
Old 02-15-2008, 02:19 PM
Hobo's Avatar
Default Hood Release Broken
I went to open the hood of my 97 Civic EX and the plastic handle of the hood release under the dash broke off in my hand.
Honda has the part for $30 bucks but it's around $150 to install it.
Anybody ever replace one of these? How difficult?
Old 02-15-2008, 02:59 PM
Default RE: Hood Release Broken
not hard at all to replace.... remove the drivers side fender and front bumper and ya should be able to see the cables route....
just be carefull not to scratch your fenders or bumper after pulling them off and laying them down. best to get some cardboard and put them on or some old sheets or something...
Old 02-15-2008, 05:51 PM
Hobo's Avatar
YIKES!
Remove the fender & bumper? More than I feel like tackling.
Old 02-15-2008, 06:11 PM
bakertime's Avatar
Wait, did just the handle snap off? If the cable is still sitting there, then all you'll need to do is remove the driver side kick panel (the plastic behind it) and remove the old handle, replace with new. I've never done it, but I can't imagine it'd be that hard. If you need access to the cable, you may be able to get to it by removing the wheel and taking off the plastic fender liner, instead of removing the fender.
Good luck! Post up some pics if you're looking for some more detailed info.
Old 02-15-2008, 07:50 PM
jamned's Avatar
He said the plastic hood release under the dash. That sounds like a pretty easy thing to do yourself. It sounds like you'll just have to remove that handle from a hinge and put the new one on. Heck, you could probably just forget a new handle and use pliers to pull that cable in the future.
Old 02-15-2008, 07:56 PM
on my 92 hatch the cable has two little ***** on each end if a 97 is the same you can just replace the handle like bakertime said. but if the cable end is messed up its still not that bad
Old 02-15-2008, 08:25 PM
sixwhip14's Avatar
This must be common. I test drove a 97 ex with a broken handle. Then I bought a 00 si with a broken handle. The kick panel on my si is loose( no screws or pins), so I just pull the panel out and to the right. Then you can easily grab the cable and pull. There is still the plastic on the end of mine so it's no big deal.
Old 02-16-2008, 12:05 AM
Hobo's Avatar
Yes, just the piece that you grab and pull with your hand broke off. The flat handle piece. The cable is still intact. I had considered pulling it with vice grips to open the hood. Maybe I'll do that until it warms up a little and I can look into fixing it myself. I live in Wisconsin and it's still COLD here.
Old 02-16-2008, 10:18 PM
sixwhip14's Avatar
Yeah, I'm in Iowa. We're damn near neighbors.
Akihrio
09-07-2012 08:20 PM
tjones07
02-11-2007 09:58 PM
thow
12-17-2006 08:09 PM
redlines4us
08-22-2006 05:49 AM
Littleneckhalfshell
02-24-2005 03:24 PM
Quick Reply: Hood Release Broken
