How to install daylight running lights on civic
Old 01-30-2008, 01:45 PM
slavo's Avatar
Default How to install daylight running lights on civic
Hey guys, not sure if this is a correct topic to post to, but can someone point me to a page/thread or urlon how to install daylight running lights on honda civic 2005?
I just moved from US to Canada and it's a requirement here.
Thanks.
Old 01-30-2008, 02:00 PM
Default RE: How to install daylight running lights on civic
well if you cannt find a OEM part to plug into the car... cause im not sure how their lights are wired up..
you can go aftermarket. this is what ive been using on my 99civic.
http://cgi.ebay.com/ws/eBayISAPI.dll...:IT&ih=010
works great!
Old 01-30-2008, 02:19 PM
slavo's Avatar
Well, not sure if this is exactly whatI wanted. The link you posted seems to be pointing to some night ligth system. Is there anything which would be applicable for Canadian DRL requirements?
Old 01-30-2008, 04:06 PM
Exhausted's Avatar
Yeah theres this little **** on the left side of the steering wheel. Turn it a couple clicks, and voila! Daytime running headlights.
Old 01-30-2008, 04:49 PM
well the link i posted does have day time driving light feature built in....... when ever the cars ignition the lights will be ON. but its also BYPASSABLE.... by simply cuting one internal wire, which is how i have mine DISABLED. best of all with that system theirs NEVER any need to even touch the headlight controls anymore!
perfect for lazy people like me [8D]
Old 01-30-2008, 10:21 PM
I have an American car and live in Canada...the car had to get a DRL module installed when it was brought across the border, its a little box with loose wires running around everywhere under the hood...if I take out the car tomorrow I will let you know some info of the module such as any markings on it, etc...now its covered in snow...[:@]
Old 01-31-2008, 04:10 PM
Firehawk989's Avatar
Go to Canadian Tire and ask for the Hamsar DRL module. It will cost you like $20 or something, and its really simple to install. 1 wire for power, 1 wire for switching when the engine is running, ground, and another wire to the headlights. Comes with an inline fuse for the power wire as well. The instructions will tell you to wrap the switching wire around one of the spark plug wires, but that worries me, so I spliced into the green/yellow wire coming out of the distributor.
Old 01-31-2008, 05:53 PM
Should be able to do it with a simple relay under the dash to bypass the headlight switch whenever the ignition is on. But if the "Hamsar" module is only $20 and comes with instructions, that's kind of hard to beat.
Old 08-07-2011, 09:35 AM
zbSmiley37's Avatar
Hey, wondering if someone could help and if this is the right thread if not direct me somewhere else. I am installing LED strips inside or around my headlights and I want them to come on with the DRL, but when I wired them in and hooked them up but they did not turn on, I thought they did not work , tested them they are fine, but when i just have the LED's hooked up no DRL the LED lights work, now I have only done this so far on my right side headlight, Do I have to hooked the another LED strip on the other side or what?
Old 08-07-2011, 02:14 PM
When DRL is on you get less than full voltage to the bulb, that may not be enough to light LEDs. Perhaps just forget the headlight / DRL circuit and wire them so they are on whenever the key is on?
Brian
16
12-25-2021 03:12 PM
itzcorky
09-21-2011 07:45 AM
Challa
05-29-2007 07:40 AM
red2000Si
27
03-08-2007 12:33 PM
Kahuna
05-13-2006 03:45 AM
Quick Reply: How to install daylight running lights on civic
