Iacv problem
Iacv problem
Bear with me, I'm writing this post on my iPhone.
Ok so I'm new to this forum, as well as hondas. I bought a 2000 honda civic ex 1.6l vtec a few days ago, and I ran into a few problems, minor electrical and whatnot. My heater wAsnt working so upon realizing that the switch to open te valve for hot air was disconnected, I cotacted the dealer to see if there was any work done under the hood. He mentioned tranny work, so I assume a lot of stuff got unhooked, which leads me to my question;
It idles poorly, almost stalls; so I unplugged the cruise control module vacuum line to the engine, and the allowance of the extra air brought the idol up to around 1k. Obviously the current setup isn't getting enough air ( with the cruise hooked up). So, after doing some research I learned about the iacv and how it works. I went to check it out only to find out that there's a 2 prong female receiver for a plug, but I can't find the damn plug anywhere? It defeats the purpose of having the iacv if its not getting the signal... So where is this plug located? What does the other end attach to? Is it possible that someone mistakingly plugged it in somewhere wrong? Is there another 2 prong reciever that could have caused a mistake in reassembly?
And could the iacv unhooked be an explanation for odd shifting with the automatic transmission?
Thanks, nick
Thanks, nick
I'm gonna check again to verify its a 2 prong, maybe I'm mistaken. What do you mean that the plug doesn't go anywhere? It's got to be attached to something!
(merged)
So I want and checked it out again. The black cylinder of the iacv has a 2 prong reciever...
But what is the piece of hardware just below the tps? It's a cream colored plastic part with a 3 prong plug hooked up?!
(merged)
Sorry to blow up the thread, but Im reading elsewhere that it is in fact a 2 wire harness
UPDATE:
Upon further research, I found out that my car has an iacv for an automatic transmission, as well As one for a manual transmission, hence why I couldn't find the plug, I was looking at the wrong iacv! So it IS there and it IS connected.
So back to my question, why is my car Idoling poorly, and why is it sometimes waiting til 3.5-4.5k rpms to shift? Hellllppppp!
Not sure how that would work since the throttle body is made for one or the other. It would be using the 3 wire one on the bottom. Are the passages made so air can reach it? Remove and clean the 3 wire valve in any case.
You can leave the 2 wire one in place and disconnected. With no electricity it will just stay closed.
Ill get a pic as soon as it stops raining
