ICM/Distributor problem
Ok so i have a wiring issue with my civic, It ran fine, messed with a few wires (and by few I mean every single one in my wire tuck) so im basically bent over a table... if you catch my drift. So i got the fuel pump running, I smell gas when i crank with no plugs in. I cant actually tell if im getting fuel at the right time. secondly I have no spark. I have power going to the distributor via the black/yellow wire. and as i said before it ran before i did my tucking. so i messed up a wire somewhere. so questions are as follows
1. How do i check if my ecu is on if i have no cluster (replacing with gauges)
2. what wires need/ dont need voltage for my distributor to work. i've herd TDC sensor and like a CKP sensor? as you can tell i'm stupid when it comes to cars...
crazyflippindude
10-29-2008 09:28 AM
GAMBOA
14
11-23-2007 01:59 PM
honda_farmboy
20
08-07-2007 05:29 PM
billthepill
07-14-2005 01:49 PM
