Interior cabin fan
Interior cabin fan
So I've been having a problem with the interior cabin fan that vents hot and a/c air. The fan works when I open the glove box and manually turn the fan. However, when the car is turned off for a period of time nothing works—a/c, heat, or the fan in general.
Any ideas what I should do. I've replaced the cabin filters, and checked the fuses; but I can't figure out what the problem might be. Does the fan need to to be lubricated, cleaned out, or is there another problem?
Any suggestions on what could resolve the problem?
Thanks in advance.
Thanks in advance.
Hi,
Thanks for your reply. The fan worked fine this morning. It seems to cut only when the car, or weather, is hot. Is there anything else it could be? And if I need to replace the fan motor can I get a second-hand one cheaply or is it an easy replacement?
Thanks again.
Thanks again.
anivast999
05-14-2011 06:15 PM
rog_ski
05-22-2010 06:49 PM
redliner25
11-01-2007 03:17 AM
