lo-beam Headlight issue
Old 01-22-2011, 07:03 AM
Hippie Lettuce's Avatar
Question lo-beam Headlight issue
ok so what needs to be done here? i have a 2003 Civic LX my hi beams work my drl and parking lights work but no lo beam. i replaced both lights maybe a year ago because the right side went out.I was hearing a buzzing noise and the drl light was flickering in the dash.Then the right side light has gone out again, it would come on once ina blue moon but then yesterday the left side went out? both drl and hi beams still work but no lo beams at all.
Old 05-15-2011, 06:38 PM
pjjam's Avatar
Default low beam headlight issue
the buzzing you hear is the low beam cut off relay is not getting enough power, there is drl module under dash under steering wheel on left side, big grey rectangular box with a blue pin connector plugged into it. you have to remove it and pry case off and slide out the guts. examine the solder contacts on board some of them are failing. just need to touch them uo with soldering iron and some solder. failing solders are reason for the buzzing relay. the relay may also need to be replaced, it is located behind glovebox on left side, you will see 2 of them side by side it is the far one. mine is grey. pull it out(up) take it to dealer and get new one. if your not confident with the soldering on drl module take it also to dealer and get new one 150-200 dollars though. hope this is helpful. this a common problem in honda's for years, had same problem in 2002 honda odyssey, pulled it out and resoldered bad joints and no more problem. just did nephews 2002 civic recently also.
Old 11-18-2011, 02:06 PM
Default no headlights, drl or hibeams
ok i bought the new relay for in behind the glove box and just bought a new drl relay so far ive spent 180$ on both parts and still no drl no headlights no hi beam nothing just side marker lights. ive checked all the fuses under the dash and under the hood none were blown. Is it possible that my headlights are dead? i bought 2 new head lamps about 3yrs ago, they should be good still right?
can anyone help me please.
Last edited by Hippie Lettuce; 11-18-2011 at 02:36 PM. Reason: adding to original post
Old 11-18-2011, 02:32 PM
When a light doesn't come on, always check the bulb first. Always. Doesn't matter if it's 5 years old or 5 minutes.
Old 11-18-2011, 02:43 PM
Smile
Thank you! i will try that tomorrow and post my progress.
blackseries99
01-03-2013 12:27 PM
sethward
01-22-2011 06:53 AM
parkov2
01-30-2009 10:00 AM
vodevil
06-17-2008 07:52 PM
liliechen
12-25-2005 11:15 AM
Quick Reply: lo-beam Headlight issue
